Adjustable Internal Wastgate
scrobbyd
Keep the adjustable rod but add a spring adjustment for internal waste gate. Kind of like the way the adjustable oil pressure spring that goes on front of oil pump that one of the venders sale. But make it wear you can adjust spring pressure, this will get rid of standard & heavy duty actuators and give more adjustment for internal waste gates.
Need to lower boost
Rjc or similar boost controller
No what I'm talking about is an actual spring adjustment on the front of the waste gate acutator. RJC controller only gives you the option to up the boost once you have a base low setting for adjustable rod.
