Well some of you know I was having a weird knock noise.Well i ordered new Harland sharpes 1.55's to replace the stockers on my car.I am getting ready to install them did the grinding of the pedestal no big deal.Grab the directions and it says must have 2-3 threads showing out of bottom of rocker.I did not see this till after I installed them and started the car.I have 206/210 cam with roller lifters and the push rods I believe are 8.225's I think.If i adjust this to 2-3 threads showing it is going to give the push rod more preload then needed.Am i correct or not....
Reason I ask this is when i adjusted all the valves I tdc then adjust intakes and exhaust and cylinders that I could then rotated motor one full turn,and adjust intakes and exhaust on other cylinders. Now buy adding this 2-3 threads showing deal I will be forcing the lifter down more and causing more preload...or am i thinking to much into this...
__________________
__________________
