TJF16turbo
junior member
- Oct 22, 2007
How do you go about adjusting the adjustable servo pin on the new PTS Extreme Servo? To be more exact, where do you apply air to make the band apply? Do you apply air to the end of the pin itself?
I understand the part about "keeping adding the thin shims provided till you cannot turn output shaft backwards by hand clockwise. Once you get to the point of the shaft not turning , remove one shim (thin ones) and you are good to go. Each shim is about .030". Thanks for any help!!
