Seems like a given but how do I adjust WOT with my scanmaster? I have the idle set at .42. I think its tps but do I have the car on with the throttle buried while I'm adjusting it? That doesn't seem right. And where do I adjust it on the motor?
2 phillips screws on passenger side of TB. Adjust TPS after the car is warmed up. Turn key on, engine off. Set to .42. Then when you go back in the car and mash the gas to the floor hard at the top of the pedal, it should go to 4.5 or higher. Then start the car, When car is idling, the IAC should be set to around 22, which is on the driver side of the TB with a torx bit.
