1dollardog
Are we there yet?
- Jan 5, 2007
What are the advantages of installing an electric fan on a hotair? Who has one on there car?
a good clutch fan will always cool better and use about the same power to run as a similarly spec'ed electric fan. remember- the engine still has to run the alternator to provide the power for the electric fan..
the main advantage is in opening things up for easier mainteance and the ability to run the fan with the engine shut off for between rounds cooling off at the track or something.
Going electric helps the engine free up lost power from the mech fan. Some claim up to 17hp by going electric, but all seem say it's a GREAT or MUST mod for HA. When i did this mod, my car ran cooler,less noiseE,drove way better. I"m sure i picked up a few MPG as well. It depends on your setup, if your stock 1500cfm fan should be good no A/C, with... try 2000+cfm. Pick the right fan, if your gonna make power you gotta be able to cool it the motor. You could get a mark 8 like I did, or Ford/lincoln Fan,dual ramchargers, whatever as long as it cools your car. you could get a metal fan shourd from a monte carlo/cutless(gbody) for 5-10bucks, bolts right up. Then whatever fan you like. Here are some pics of my setup, hope this helps.
Which is right?
