Aftermarket/Performance Parts!
Daniel Jost
Squirtin six
I have a couple things for sale that I'm selling from my current setup, and that I had laying around. I'll try to get pictures soon.
All Prices Are Plus Shipping;
- Innovate LC-1 about a year old with a new sensor that has less than 1000 miles (Mostly on E85) $130
- 86-87 Stock upper plenum that has been chromed and mild ported, chrome is pitting. $30 SOLD
-86-87 Stock Throttle Body, Has IAC and mount but wire plug port on IAC is broke $40
-3 Gauge Full Pillar, Gray in color in good condition with some minor wear. It has 2 LED's mounted next the the gauges that I used to use for Alky/Fan indicators. $40 SOLD
- RJC Boost Controller $25 SOLD
- Home made Megasquirt3/X to Stock Buick Harness Adaptor, It has the wiring for COP, 2-step, Boost control, WBO2 already wired. If you are following my "Going Megasquirt" thread you could Probably make use of this. -$80
- 86-87 Stock WG actuator. $25
- 86-87 Billet Vacuum block. $20 SOLD
- 86-87 Good working TPS. $25
I might have more stuff I can add later as well, I will need to look through the garage.
-I have found a Auto Meter Electric Water Temp Gauge with the sender, it is a Pro-Comp Ultra-Lite Series. $30
- 86-87 ECM with correct Cal Pack and Turbo Tweak 42# Injector Nitrous chip in it. $55
,Dan
The LC-1 does not have a gauge but it does have the data cable. I will be getting pictures of everything when I get a chance.
,Dan
I finally have all the pictures ready to upload, I also added an electric temp coolant gauge and ECM that I found.
- WBO2 Picture is up but I forgot to grab the WBO2 out of my car when I was at the shop so its not in the picture, but it is in just as good of condition as the LC-1 Controller. If needed when I stop out tomorrow I can grab it and take a picture.
- The Megasquirt adapter harness should not require anything else other than a MS3x setup and a WBO2 sensor and a base tune loaded to get set up and going, I have not wired in the speed input yet on this adapter so that would still need to be done if you wanted auto TCC control. Use these links to find out more about it, I would recommend that you read into these links to know what is involved in building an MS3 to make sure it's right for you. http://turbobuick.com/forums/threads/going-megasquirt.333796/ http://turbobuick.com/forums/threads/the-official-ms3-x-build-thread.354674/
- The 3 gauge pillar is Grand National stock pillar Gray, I noticed when taking pictures it has a small hairline crack at the bottom below the third pod that is not easily visible when in the car and I tried to picture.
,Dan
First Set
Second Set
Third Set
Fourth Set
Fifth Set
Please let me know if the other member isn't interested in the vacuum block.
Paypal ready.
Thanks!
