I have a grant steering wheel I wanna install. Pulled the old cap off. There is one wire with a spring around it. The grant wheel has two prongs on the back of it. Do I have to cut some wires or fabricate something?
Cant get the horn to work. The button on the factory wheel works. When installing the wire with the sping on it.....if I touch the center bolt the horn will sound. When I have the spring in place and hooked up to the new horn....the horn will not sound. I only see one wire in the install kit. The back of the steering wheel has a connection for two wires. I assume you are just completing a circuit. Not sure what I am missing. Will try to post pics later of all the components.
I figured it out. Guess I just had the spring wire in wrong. Put it back in,,,,had to fabricate a ground wire for the second connection on the back of the horn. Works great.
