Aftermarket valve covers
tford
Registered Member
I have Allen head bolts on my valve covers on new build. How are you guys mounting things like boost solenoid, plastic harness bracket, etc with the new fancy bolts? I hate to take them off and use the factory ones. Any ideas?
Most of the bolt hols on the plastic DS conduit are blown out and/or split. When I had mine, I pushed the holes over the bolt heads and they were happy there.
On the boost control solenoid, just trim the corners with a set of tin snips, then it can go under the bolt with no problem.
