I just don't believe it. Blew both head gaskets last week Monday morning on the way to work.
Long story short, I pulled the motor since the rear main seal started leaking and #4 had a exhaust valve that was missing part of the valve. Well, last weekend I got everything put back together and she fired off right away... much pride was felt because it was running the way it should be. :biggrin:
Anyhow, fast forward to Monday morning. I thought I'd take her to the car wash since it had been in the garage for over a couple months while I was working on her and was very dusty. Go thru the car wash and get ready to pull out onto the main street. I pull out onto the street and give her some gas, revs are coming up, about 3500 in first gear,and about 8~10# of boost, and then out of nowhere.....boom! Backfire....and was it loud....next thing I notice I've got smoke coming out the exhaust, and out from under the hood..oil landing on the exhaust..I could smell it.. the car is now running like crap, and I'm doing my best impersonation of Cheek and Chong...Up in Smoke. People behind me were putting on their lights to see. Thankfully I was 1/4 mile from the house so I figured I could limp it home, well I got her home and parked it. I was so PO'd...all the work I did has just been ruined in a split second. Well today I finally started to look at it. Oil is everywhere. It shot the PCV valve out and it looked like a stream of oil shot up, hit the underside of the hood and covered everything. Pulled the intake, and you guessed it, the fire ring is protruding, and I found bit's of it in the oil valley. Time to pull the motor again and fish out the pieces of HG that probably found their way to the oil pan.
Guesses as to why it backfired so violently? I can only think that some water found it's way into the plug wires, but I had sat for about 5 min, engine idling after I got out of the wash booth, surely everything would have been dry?
Steve
Steve
