Air Bag Pressure
viperkiler
Well I have my final recipe and ready to go!!!I only need the right pressure for my air bags though.87 gn 36#blue tops,t49 turbo,fuel pump and reg and hotwire,k&n cold air,7 setting ultrachip,pinian snubber,airbags,hoosier 15x9s slicks,Need air pressure on those also....full slicks not drag radials. and what can i expect at the track on friday night?
I put about 20 psi in my right side are bag. For slick pressure, try around 15-16 psi to start, lower it a couple pounds as required.
As a word of advice, I wouldn't play too much with the pressures first time out. Use one set-up a few times and only try to change one thing at a time. First time out with a new combination will set a baseline that you can build on. Trying a lot of different things every run won't give you a good baseline.
I ran 8 pounds left and 23 right with 13.5 in the ET Streets this past weekend. I have no posi and was able to get both spinning in the burnout box, though the right rear was definitely a lot busier. Best 60' was a 1.96 on an airstrip used for drag racing for the first time.
As for what to expect, I'd say somewhere in the 13s. That way you won't be disappointed. ;)
