air Temp dosnt change on Scanmaster :(
thunderace31
Banned
Air temp is not changing on my scan master :eek:
Is this just a bad Air Temp Sensor?? I have not replaced it yet but it always says air temp is 128* and it never changes. I installed a cold air (Big Mouth) kit and that is when I notice it should not be that hot What problems could this be causing if any also?? :confused:
Just want to see if anyone else has had an issue like this before I buy another part lol.
Thankks
Guys again for your input
The good news is that the MAT doesn't do much in the grand scheme of things (as you apparently proved to yourself)...
strike
Thankks
i once found a resistor inline with the ats wiring about 3 inchs from the sensor and it went bad. i was told this resistor fooled the computer in to thinking the air was cooler and add more fuel. when removed it worked fine.
Ya I kinda figuerd it didnt but I still want it fixed so the car runs its best. I just pulled it out and looked at it and its kinda black looking so I think its bad. :confused:
I will also chech for the resistor inline with it and see if it may be the problem. Just not up for spending any more money if I dont have to sales are down for me and funds are way tight :(
Thanks for the info guys :) :D
