VadersV6 said:You should mount it in the intake tube. But, if you extend it and mount it behind the headlight where it can get a cool fresh breeze, it will dramatically reduce the timing retard that happens from heat soak. Some timing retard is triggered directly from detonation, and some happens as a result of the air temp sensor readings. Its a liability thing thats put into the code of practically every EFI car out there. You can thank the warranty companies for bringing that around...as well as shift retard, tip-in retard, etc. They figure the car is more likely to detonate in high temps, as well as high coolant temps, so they pull the timing when it gets too hot. I actually used a different thermistor (thats what the actual element in the sensor is called). I used one that reads about 30 degrees colder than ambient and stuck it in the plug. Now when my car heats up, it doesnt feel like its lost a bunch of power. On my old car, I spliced a resistor inline with the sensor to make the computer think the incoming air was cooler cause I didnt have another thermistor. A thermistor is a resistor that changes resistance depending on temperature. All the retard that comes from heat soak vanished. In many cases, making the computer think the air is colder can increase timing advance by a few degrees....not just eliminate retard.
Good to know. But, for warranty purposes, they have to have some means of pulling timing before detonation even starts. Its usually a value that comes from matching the coolant temp readings with the IAT readings, and the base spark curve is pulled down a few degrees. Then if detonation is sensed, it pulls even more. For GM to not do this would be strange, given that all cars have some means of pulling this off.bruce said:The only effect the IAT has, is for fueling. In the N/A applications, the IAT timing stuff is used.
VadersV6 said:If you have cold air induction like that guy, your heat soak timing retard will practically be eliminated. Ive always believed that a good portion of the track gains from a cold air setup can be attributed to keeping the sensor from spitting out high temp readings.
Ive tried cold air setups before, and I did feel a slight improvement in power, (but driveability sucked) but I got much better results (dramatic) by just having the filter under the hood, and fooling the air temp sensor to spit out cooler readings. I remember back when I was playing around with different resistor values, and if I got too high with the resistance, and the IAT readings got too cold because of it, my car would develop MAJOR tip-in detonation cause of the added timing. It sounds crazy, but its been proven time and time again with many EFI cars.
Does it ever feel like your car has lost 50 hp after it heats up? Throttle response goes to hell in a handbasket? Engines are supposed to make more power when they heat up. You lose the power because the computer is pulling timing from having high temp readings. And the retard wont show up on the scan tool.
VadersV6 said:Good to know. But, for warranty purposes, they have to have some means of pulling timing before detonation even starts.
I said "it's good to know" that it doesnt exist in the TR programming. It does exist with other EFI late model cars though. Practically all of them. It would only seem logical that GM would have created a base timing retard when things heat up, unless warranty claims didnt concern them. It sure concerned everyone else...or maybe it was just too early on in the EFI world for them to have thought of doing that. Would they have any means of doing this other than coolant temp readings and IAT readings? So the IAT readings alter MAF correction? Could that have an effect on timing? Ive seen timing change via altered MAF readings. Could that be how its done?bruce said:Show me where in the code this ability exists.
I've spent some time on this subject, and there is no way in the TR code for the ecm to *pulling timing before it starts*.
Just to be specific, I've looked at both the PROM, and ROM, in very close detail and just haven't seen what you're claiming exists.
VadersV6 said:It does exist with other EFI late model cars though. Practically all of them.
Why is it that I'm getting KR at lower boost levels ever since I put in the different thermistor? My BLM's havent changed. O2 readings at WOT havent changed. Too bad I have no means of looking at my timing so I can see first hand, although I do take your word for it.
fontana said:Is anybody here saying there is no tip-in timing retard for a stock 148 ECM?
Wayne
