air to water intercooler?
"More Boost"
Major Member
where do i go to find an air to water intercooler for my 87 GN, i went to spearco's website and everything on there seems custom (taylor) made, surely someone makes a bolt-on intercooler for this application? any help would be appreciated, thanks , Gregg
Air to water is something that not a ton of people run on street cars, and would be far different configuration then a street car. If you're doing an all out race vehicle, get a Spearco unit and make it fit. For a street car (depending on how loosely you use the term) an air to air would be easier and probably weigh less in eventuality. I may be a hyppocrite in using air to water on a street car myself, but guess what I never have an never will be known for doing things the easy way and if I get fed up with it I'm goin powerstroke IC.
I'm going with a Syclone upper for my setup, the lower's a radiator from a Geo Metro with the E-fan. The Sy/Ty ICs have an obvious weak point the input neck is terribly small, I'm planning on rooting mine out pretty heavily and/or "big necking" it somehow. There will be one of those 5 gallon drink coolers in the back stuffed with ice when I wanna have fun as well. A lot of the Sy/Ty guys use a Shurflow pump (google for the numer) they're about $60-70.
http://www.key-ideas.com/AirWaterIC.htm
here's a link for you to pick through, get some ideas of what goes into one of these setups, expensese and benifits. Any setup will probably be all custom design and installation, inherintly expensive. If there are hot air guys out there complaining about intercooling making your car like every other GN, I present this as a suggestion. Your GN definitely WONT be like every other one on the block.
