Originally posted by Razor
So while spraying your O2's went up and the EGT's went down..
And the IAT's went down as well..
Surprise
Yeah...I figured that would happen! But, I was surprised the O2s werent a little higher considering how rich I was running it and how cool the exhaust gas was. But hey.....who cares. The car seemed to be running fine
I will however put this issue to bed when iI hit the dyno in a few weeks. I am going to vigorously log O2s, EGTs and the wideband A/F and see how all of these relate to power. Once I find the "sweet spot" for the car, Ill know what to shoot for from then on.
Now pull fuel out and drop the O2's with the kit spraying aggressive... and get it down to .86.. And watch the power take off...
Thats how you start the replacement.. from there timing.. and keep an eye on the egt's. as the O2 and EGT will always correllate unless there is detonation. At which point the egts will climb.
So you can bring it to its knees.. thats a wonderful thing
I will try to get O2s down a bit and see what happens.
Question......
If I change the initial turn on psi on the PAC, will I then need to readjust the gain knob to get the same amount of spray under full boost? I currently have the turn on point the same as the PAC is shipped, which is about 4 psi or so I believe.
I ask this quesiton as when I turn the boost up a bit and set the gain so it gives perfect spray up top, it sprays a little too much down lower (in the 4000 rpm range).
Heres the other thing I found......surprised me big time.
When I overspray the car with methanol down low, the turbo spools faster! I noticed the car felt snappier down low after I added the methanol, but thought it was in my head. Then I datalogged it. Boost definitely ramped on faster. In fact, the boost came on in the same fashion with the methanol as it did when I spray a 15 shot of N2O!
Take a peek at this quick screen shot. The runs were started at slightly different rpms, so thats why one is much below the others right off the bat.
The dark blue line is boost with 93 octane gasoline and methanol spraying at 4 psi turn on point and the gain knob set at 12.5 oclock. The light blue line is is with 93 octane gasoline at 50m psi base fuel presusre and a 15 shot of N2O. The black line is on just 93 octane gasoline at a 50 psi base pressure.
The boost goals for these runs was obviously a little different as you can see where the curves level off
You can also see the ignition misfiring on the dark blue curve as the boost line gets funky looking.
Any ideas why the turbo spools so much faster? No complaints of course
