Just bought an alky kit. Now I need another up pipe (want to keep my stock pipe), a street chip for 93 pump gas, and a race chip for Turbo Blue unleaded (I beleive 100 octane). Injectors are 009's. See signature.
Perry, i run 009 injectors in 2 of my limiteds, if you just purchased a alky kit, i can only suggest you get a alky chip for your combo and injectors.
I am wondering if you have heard about the tip in stumble on the 009 injectors? With Erics chip, i have never had a issue with these 009s on 3 cars, his chip works very well with them and you can adjust fueling and timing inside the car if need be.
I would at least try one of Erics chips at TurboTweak Home with the alky kit and you probably wont need the other chips.
Thanks for the tip, Bryan. changing chips hasn't been a big deal for as often as I go to the track (3-4 times a season), but would be nice to forget about it. I've generally heard good things about TT and will check it out. Thanks again!
Thanks lpaulabbott - Is that a stock aluminum pipe, after market, painted, coated, plated...? Can I get a picture? Take paypay? Otherwise, please send your address. Thanks!
I have a very nice 3" chrome buickgn (Mark's) up pipe drilled for AKLY
and TT 93 ALKY chip for 009's and
3" chrome cold air intake pipe both were used with a TE44
both with hoses and clamps
Intrested?
