alky control not coming on??
figga8n
Took car out today and noticed alky not working. Led light would not come on as it did in the past when alky starts pumping. I hot test light and the led lit up but the alky didn't come on automatically! This is a pretty new system and has always worked before. Is there anything I should check??
does the car stumble a little at idle when you hit the test button? If it does I'd check your map sensor wires and vac line going to it. Test for power at map sensor like julio's installation instructions say. Hopefully you still have them, but I think a quick search should get you those...
Never mind
Called alkycontrol he told me the problem in less than 30 seconds! I don't know what is better the alky kit or the service:cool:
