Alky dyno results
Sweet6
TTA 1216. 20lbs of boost through closed exahust
320HP/350TQ AF was 11.5. O2 volts showed 81X's. Base FP at 40PSI gain knob on dash set to around 4.5. Just wanted to share.
That dyno has to be broken.. there's no way that's all your car made if its been that fast.
Different car than the 11.83@114. I have not run the Alky car yet.
Even still.. Just seems awful low. Shane's TFS car made about 50 horsepower more with a stock turbo and intercooler.
This dyno does read a little low compared to other dynojets in our area. About 20HP less. The car that ran 11.83 dynoed at 365HP on this dyno last year. Raceweight was 3700lbs.
Also, my buddies LS1 did 365 on another local dyno last fall. That same car did 340 on the dyno I used. Both were dynojets. The numbers do seem low on the dyno we used this weekend. I was more concerned with using the wide band to check the AF ratio.
Car should have made more power. But hey.. a good day at the Dyno is one you drive away from the rollers.
Also tune meth upper 10's for AF, not mid 11's. Your chip controls injectors.. that is where changes to injectors should be done. If the car is rich.. add more boost :D
I thought in your tuning the Alky on the sticky said shoot for 11.50-12.00? I was using denatured if that matters. I will be using Meth the next time around. That was all I could get on short notice.
i am running 11:00 to 1 in my car and trapping pretty good with the 44 in a full weight car...these cars love fuel.............................hth Bob
