Torque numbers
You bring up some good points!
I'd also like to hear from the turbo gurus regarding the torque produced by the newer turbos.
Seems somewhat disappointing for a torque junkie.
Was looking specifically at the 6265 and 6765,
as those are both what my combos would call for when it comes time to upgrade..
Less torque than their older counterparts..
TE-44 pulls
2nd pull = 316.9 hp @ 5089 rpm / 364.7 tq @ 4132 rpm. Boost 16.7psi, 18* WOT timing.
Billet 6265 with ACBB pulls
2nd pull = 319.8 hp @ 5447 rpm / 333.9 tq @ 4796 rpm. Boost 16.7psi, same timing.
_______________________________________________________________
Cast 6765 dbb, S cover.
2nd pull = 452.8 hp @ 5061 rpm / 474 tq @ 4970 rpm. 20.9 psi.
Billet 6765 air cooled bb, S cover.
1st pull = 429 hp @ 5110 rpm / 448.6 tq @ 4847 rpm. 20 psi.
And for the record, I'm not a billet wheel hater either.
Have many PTE products on both my cars, and looking forward to pte ball bearing turbos for both of my cars in the near future.
Just want the most torque possible being as they're both street cars......
Do NOT want to give up midrange torque that makes the cars a blast on the street for more power up top for a car that will rarely or never see a track.
Would it be better to stay with cast wheels for someone in my situation??
I was ready to convert to billet dbb for spoolup alone, but if it means loosing torque
very confused now
Ok... I wasn't going to post anything but... And FWIW, I'm not a billet wheel hater as I had one of the, if not the very first billet 6768!!
But last year on Richard Clark's dyno we had a Te45a P-trim car make more HP & TQ at the same boost level (20psi) as the 6765 car listed above with a smaller combination otherwise!!. We never went higher than the 20psi with it...
Also last year we had a car there with a very old version Limit Engineering Te70 Q-trim that made the same HP but much more torque as Derek's billet-71turbo at the same boost level (24psi). Again with a smaller combination otehrwise!!. We never went higher than 24psi with it.
I'm not posting this to "call out" anyone's car, combination, or tuner. But I would like to hear thoughts from the turbo guru's....??
K.
TE-44 pulls
