Alky from IAC
Tin Man
I just started having this problem. Very hard to start hot or cold and smells very rich at startup. Otherwise the car runs great (idle, cruise, wot). TPS, IAC, and o2 looks good on scanmaster.
Decided to take out IAC and clean it. When i took it out, about an ounce or so of alky came out. I had just driven the car about 5 miles and didnt even get into the boost. Furthermore, I had my SMC control off. I am thinking that alky is being pumped in on startup and drowning spark?
I have the SMC dual nozzle kit. Steve gave me the 7lb jets to accomodate the stock turbo, injectors, intercooler. I will eventually be upgrading.
Any ideas?
TIA,
Zac
Unplug container power connections and see if it still happens. I dont think you can siphon that much alky to get into the IAC. Chances are its spraying when you think its not.
