Alky Gains?
EGOKILR
Dont Worry, Be Happy.
Just curious, What kind of times or horsepower did you pick up using alky?
I am going to hopefully be finishing up installing Razor progressive soon. Please post before and after. When I finish installing my vacuum brakes, (Power master went out a second time, no chance the fuse is not going to help anymore), I will also post my times with and without.
Tough question to answer becuase of the way it was asked.
Example at same boost level?
At same timing?
At same air fuel?
See if your car is tuned at 16 PSI and you spray alcohol without changing anything.. your power will drop. Now if you increase your timing from 18 degree's to 24 degree's, bump your boost from 16 to 25... see where this is going.. you will pickup a tremendous amount of power without setting of your knock sensor.
Same can be said of "Gains" using race fuel. You drop in power switching to race gas "Unless" changes are made to the way the motor is tuned.
HTH
Thank you, that was very helpful
This making alot of since now, I am new to the alky game and was just wondering what kind of difference it would make. Now I know, there are alot of variables to be considered in the equation. Thanks
