don;t get too excited I was talking to razor and it looks like they don;t flow very good.
INTRODUCTION
Here is a valve that will out perform any fuel injector, this stainless water injection valve was designed specially for high level racing applications and is now available. Coil resistance is 13 ohms
MINIATURE SIZE
The HSV (High Speed Valve) is very small , measures less than 50mm in length and 14mm in diameter excluding the electrical terminals which protude approximately 6mm from the body.
HIGH SPEED
The most important measurements of a valve's performance is speed, the higher the speed, the better the control. This valve can cycle up to 250 cycles per second.
HIGH FLOW
The valve has and orifice of 1.4mm and maximum flow of 500 CC of water per minute at 4 bars
1cc/min=.0159 gal/hr =7.95 gal/hr@58 psi=10.44 gal/hr@100 psi
a single m10 nozzle flows 10 gal/hr@100psi
So it would be marginal for a single m10 nozzle even
