Alky Nozzle Question
TRYMYSIX
I currently have the newer SMC kit and have no idea what size nozzle I have. Looking at my sig below, what size nozzle should I be running? Also, will the Alky Control nozzles fit this system? Thanks
Why you going down in size? Why not simply reduce the ouput from the controller .. meaning voltage.. and that will put in less.
We use the same tips.. just different mounting methods.
HTH
The SMC kit won't allow me to adjust the voltage will it? I have tried many settings to try to get the stumble out at the tip in. I have it set now to start at 12lbs and full voltage at 20lbs. Running 20lbs of boost.
