Alky & Power Plate
5ltretr
Should I keep the Power plate or toss it?
I dont want the alky to soak on the Plate , if thats possible?
thanks
I can't speak for what you 'should' do but I still have my plate and run alky.
I think of it as the plate is still equaling out the airflow and the alky is lowering the temps.
I run the power plate w/ my SMC kit & can easily run 24 lbs of boost on 93 octane w/ 0 knock.
The Darkside:cool:
I would keep it in. It will not get soaked by alky anymore than the TB or intake. I think you would want equal amounts of alky and air to each cylinder.
The nozzle is designed to saturate the air going into the motor. The saturated air has to find itself into the cylinders.
Think of it like sneezing. Air carries the mist.
So yes keep it especially if your getting results.
