For DIY, I would actually recommend the Shurflo... you will still have to check/test it every so often, esp if you run Meth and/or leave it sit. The Razor on here has a mod for his shurflo units nowadays which I have no exp. with.
I tried finding reasonably priced meth comp. pumps, but the only thing i found that is already mass produced are the weldons... then again, they too need extreme care and maintenance, although they will likely never have an 'in use' failure IF you properly care for them... the internals are tool steel so you can imaging what dry, condensation, water mixes can do to that. This is why my crazy design (and "way too much money one", coincidentally) doesn't use a pump. But I am still using Shurflos on my own personal ride and others' with no probs yet if you keep after them. Besides, they are 50 bux.
Pressure depends on your ultimate flow goal and the nozzle size. Generally, 100psi is plenty for decent atomization on most nozzles.
Phil
