Razor or any one else, I hope you can help me. Just lately as I drive the GN around normally not in boost, I 've been noticing the light flicker intermittently red. Sometimes green but not as much as the red. And as it flickers, I hear a click it conjunction with the flicker. Is this a ground issue? When i get in boost, its normal- red up to 10 psi and green past that. The tank is full and the "test" works fine. The car sputters when I press it at idle. Any suggestions?
James
James
