Thought i'd throw this out there for those that like to tinker.
Since there is the ability to run multiple maps through a change of a switch, ie the TW. I have a different thought.
Run a street program whereby the resolution selected is concentrated on the lower rpm areas. This will allow better zero'ing in of fueling at low speeds and part throttle. In other words make the spacing in the RPMs like 200-250 RPMs from 600, 800, 1000, 1.2, 1.4, etc..-2k for example. That way the bubble can have better resolution. And the upper tables <5k can have larger amounts of fuel and lower timing. Follow me so far.
Now the race program will have the RPM's concentrated in the upper end. Like 5600,5800,6000,6200,6400, etc.. So far so good. As well as higher timing.
The alky system uses a pressure switch that can be tied into a relay. Once the system develops pressure, it flips to the race program. So cruising the alky is off your in the street mode.. stand on the gas pedal, alky makes pressure.. flip it to the high timing, high resolution race map.
I'd like to get the boost control feature figured out on the XFI. So we can run a low tension gate and allow it to control boost as well. On the AEM this is possible. And would then add one additional layer of protection. Maybe FAST can do the feedback deal.. that would really make it sweet.
Just tossing ideas out
