Friend of mine is doing up an Oldsmobile with a procharger on it and was talking about how expensive it would be to run race fuel all the time with it. We got to talking about running an alky kit with it similar to the typical GN setups. Is it possible? I've never ridden in a procharged car but I assume the boost comes on rather slowly and it would need a progressive pump controller to prevent bog. Also don't know what it runs down the highway if it's under boost or not, but doubt that's a problem. Probably going to run 20 psi with this thing, blowing through a carb. Would the alky affect the carb, or would he have to use a nitrous style plate under the carb to make it work? It shouldn't need the alky on until 10 psi or so. Any thing else going to be a problem?
