Ally and tt chip
87gn1
I need some help I have my 87 gn has a tt chip from Eric and 60 lb injectors I want to add ally kit do I need to have a new chip burned for this right now I'm running about 14 lbs of boost how much more can I get by adding ally kit thanks for all your help in advance.
You need a chip for the alky. It changes timing etc and is way different. Alky chip at part throttle pulls much harder, you will love it. New chip is $85 but i have a chip for alky/60s from my car i just sold i will sell for $50 shipped if interested.
Leave the chip alone. You can run way over 20 psi on that chip. Actually 25 psi.. Since the alcohol is a fuel, it makes up for the extra fueling above the 16 psi it was designed for.
The alky chip feature more timing basically. And once running on the street chip, crank the timing up and your done.
