Alt wiring ???
Martin U
I was replacing my thermostat, thinking it was a 180. After putting it back together I noticed a leak. I use a very thin smear of "right stuff" I have never had a leak after using this stuff Back for another gasket.
But I did notice a loose -broken wire from the two wire alt. I the plugs at the white two wire were both loose .I may have mixed them up. One is white, red is the other color. It seems I must have spliced the red one to extend it. But I cannot find a broken lead anywhere that it might lead to. I tightened the batt cable down sums and it fired just fine, The spark looked good on the three SP wires the ware disconnected. I was impressed at the amount of spark'
Thanks for helping . I can barley use flashlight batteries.
PS If you wouldn't mind take a look a a PL run IN the scan tool section.... AM I getting anywhere? http://www.turbobuick.com/forums/scan-tool-tech/322254-am-i-cetting-closer-my.html
The more people IC their HA Car The more I Like Mine. I would op fore rarity, against belly button cars any day
Mart Urbanski
I believe the wires are as such...
Shows here one wire was brown and the other is red.
The brown wire (i'm guessing) is the one that is white in your case.
The red wire on my car curls back around and attaches at the main battery post on the back of the alternator with an eyelet connector.
Thats the best I can do for a schematic for you.
Jerry jr.
