Alternator rear brace
Scarab
Can anyone post a picture of the rear alternator bracket? Mine is missing and I don't have anything to go by., I have GN1 heads and I don't know why they left it off. I need to know where it bolts to so I can replace it.
Here you go.
There's two brackets back there.
Any pics?
If you look closely at the pics already posted, you'll see the long one and a shorter one that mounts lower on the back of the alternator. I just replaced my alternator and found I was missing the nut that holds the two brackets at the bottom.
Sent from my SAMSUNG-SM-G900A using Tapatalk
I don't see on my alternator where that can go. The tree mounts to the rear of the alternator and to the top bolt as well as going down to the header bolts
Maybe you have an Impala SS alternator. If you are using the Impala SS or other non-stock unit you may not be able to use the smaller mount. I’ve been running an Impala SS 140amp alternator for years without the small bracket and without any issues.
aaron
Sent from my iPhone using Tapatalk Pro
^^^^ Treed!
The short "L" bracket connects with a long 15mm head bolt, through the back of the accessory bracket, through the AC compressor to the "Y".
Now hopefully you can find the bracket that you need from someone on this forum.
