Jun 16, 2013 #1 C calais1965 Member Joined Mar 10, 2009 Messages 331 What is torque value for Gn1 alu heads with studs?
Jun 16, 2013 #2 N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Messages 9,208 We use 70ft-lbs for alum or iron heads, studs or bolts with ARP lube on the washers.
Jun 16, 2013 #3 C calais1965 Member Joined Mar 10, 2009 Messages 331 Do you re-torque heads after running engine hot?
Jun 16, 2013 #4 C calais1965 Member Joined Mar 10, 2009 Messages 331 Nick Micale said: We use 70ft-lbs for alum or iron heads, studs or bolts with ARP lube on the washers. Click to expand... Do you re-torque heads after running engine hot?
Jun 16, 2013 #5 T Ttype6 Well-Known Member Joined Aug 17, 2004 Messages 3,902 calais1965 said: Do you re-torque heads after running engine hot? Click to expand... It depends on the gasket used.
