This one has a ding in the top above the drivers headlight area. I pulled most of it and it's 100% functional as is, a show car quality install would require some filler. (To make ANY of these a show car part you'd have to do some work to the tops anyway. They aren't plug welded and finished near as good as a steel one.) Also there's a tab that's cracked under the hood latch area, can't be seen when installed. And yes, the steel threaded inserts are rusty but ALL the threads are good, none stripped or broken off.
$250 SHIPPED in the 48 states. And shipping is not cheap on this. Pick up in northeast Kansas would be quite a bit cheaper.
Postal money order strongly preferred.
