Hey guys. I am trying to run an amplifier to my radio which has some RCA preouts. I didnt have any RCA cable to begin with, so i used some RCA plugs and some coaxial cable and made my own. pluged it in, and then hooked up the amp like ive done in other cars. the only thing that changed was that I didnt use real cable which I tried to make. the cable is like TV cable. when I hook it up to some 6x9s to test it out, it doesnt play at all. it just makes this very very very high pitched squeal that peirces your ears. What could cause this?? I tried it again today and it didnt do anything. no sound, no squeal. no nothing. are these crapy homeade cables the problem?? or is there a problem with the amp? the power light comes on. it seems to work. I also would like to know how if im running it correctly for a sub. I ran the two coax cables from the preouts on the radio to the low input RCA plugs on the amp. I left the high input off because I dont have any wires to go to those and I dont want to try and run treble through my sub. so I thought the low stood for low frequency. am I correct?? and what do I do with the output wires since its a 2 way amp. do I connect them and make it mono? or do I just use one since im only using a single 10 inch sub??
thanks a bunch
sorry if these are stupid questions
thanks a bunch
