amp settings?
87gnblackdemon
Don't Be Redikulas!!
I believe I asked this question before, but now my setup is different. So, What do you suggest I do with my amp settings?
Amp: 800w Autotek Mean Machine
Subs: 2 12" JLw3v2's, 1.5ft^3 per sub, selaed box.
Amp settings: subsonic filter- on or off
Line Out x-over= hi, flat,low.
Amplifier x-over=hi,flat,low.
Low variable= 40hz--750hz.
Bass boost= on of off.
Sub info link:
http://www.jlaudio.com/subwoofers/pdfs/12W3v2_DS.pdf
kind of a broad question. Depends on what type of music you listen to and how you like your bass, there isnt really a "text Book" way to set your amp up. A general method is to turn your system up as loud as you would listen to it and set your amps so the subs just start to distort, and then turn the gains back a little. That should put you some what in the ball park, just play with it a little..:D
yeah when you go tune your system make sure you go in like an empty parking lot, no neighbors or cops to complain. I shook the hell out my neighbors house when i was testing 4 12's and she didn't like it too much.
