ams500 controller users
J-B Racing
Forced Induction
Question for those using Dual Ports external Gates. Is your Bottom Port of the WG taken from the Intake or Turbo Port?
Mine is taken from the Intake. Just doing a survey..
Joe
Mine is going on the turbo
Why would yours be from the Turbo? To my knowledge the Intake would blow more pressure than the Turbo! Right?
Reason for all of this is that I am having a Boost issue that I am stuck up at 35.. Trying to sort out of I have to get more Air or a Weaker Spring..bla..bla..bla..
Thanks for answering. That will give me more to explore.
I was instructed to use CO2 on the top port and turbo pressure on the lower. With pressure drop thru the innercooler, the turbo compressor housing should be slightly higher than the intake. The intake will see a more accurate reading of what is getting to the cylinders. At least that's what I think.
**** That is what I was told.****
Thanks for the confirmation. This means I was O.K. with the porting.
What size did you port the housing to? I have to do that myself and need to figure it out.
