excobraguy
- Feb 25, 2007
OK, so i've been away from turbo Buicks for over 8 years now and recently picked up an 86 GN. I have found that the more I read the more I suffer from over analyzing my needs and wants. I want an 8 second GN but I really only need a mid 10 sec car and also only have the budget to have a mid 10 sec car, maybe????
What i have to work with is this:
86 GN with recently rebuilt motor, not a 109 block. It's a 3.8 block with the tapped turbo drain hole. unknown to me what is in it internally. Leaking oil out the drain line too!
Turbo, unknown what size it is, not Stock but is a Garrett. Has RJC boost controller, runs 15-17 lbs
AEM A/F digital A/F gauge installed, works great. Car stays at 10:1 under boost, running rich.
Spark plugs, haven't checked yet to see what they are.
Injectors, 60lb is all I know. Unknown as to the brand they are.
Stock intercooler
Stock MAF with K&N filter
Dual Electric fans, 1 runs all the time the other one has never kicked on.
Has a NX Express nitrous kit with 75 shot running Maximizer 4 progressive controller (for sale!)
Stock rearend with M/T drag radials
Accufab regulator
voltage booster
Tranny, unknown if it has been built, torque converter size unknown. Shifts good, has stumble sometimes shifting into third though, accompanied by "turbo sneeze". Has manual trans brake installed.
Has a TurboTweak chip for the setup that is on it.
No Alky installed.
So....I'm at the point where I decide where to start. Do I rip the motor out and build one where I know what is in it? How do I know the block I have is even worth keeping? Maybe not even a turbo crank.....
All I'm wanting to do is get to a reliable mid 10 sec street/track driven car. Just need a little help on deciding where to start. I'd say my budget is in the $6500 range to get there.........your thoughts and comments are appreciated!
Previous owner knows nothing about engine/trans etc. and could not even put me in contact with the guy he got it from, so no hope there! I'm a systems analyst by job trade so of course I am over analyzing everything. Just looking for input as I'm sure others have been where I am today.....so what did you do to get the ball rolling?
Thanks,
Dean
Stock intercooler
Accufab regulator
voltage booster
No Alky installed.
Thanks,
Dean
