Just wondering if it would be possible with the correct back spacing to run this tire on an '87GN w/o notching the frame?
The 275/60 is listed as 11.5" wide... these are 12-1/2" wide... that would be 1/2" om the inside and 1/2" on the outside.
I have run a 275/50 (also 11-1/2" wide) on a 15x8-1/2 with a 3-3/8" backspacing. I had to roll the fender lips..... but could easily go to 4"... maybe even 4-1/4" (with a 4-1/2" BS wheel with a 1/4" spacer) backspacing and possibly even out the clearance (inside to outside).
