turbo87regal
- Nov 12, 2005
Well I have been searching for days and can't seem to find the answer I'm looking for.
I am looking for a visual comparison of how different brand AFTERMARKET weather strippings fit. Can someone please post pics of the fit at front and back molded ends of the upper and lower door seals and also pics of the 90* corner at the back of the hard top upper seals.
I AND EVERYONE ELSE ALREADY KNOWS THAT GM SEALS ARE THE ANSWER TO EVERY WEATHER STRIPPING PROBLEM so please don't post "get GM seals"
There has to be a decent fitting aftermarket option out there.
Here are some pics of my GBodyParts lower seals. I'm trying to see if there is a better fit aftermarket set out there or if I should just stick with these. I have to stretch them fairly tight to get the screws to go in and I think they will just rip throught in a matter of days and also notice the big gap between the door panel and the seal. The front also has the same issue with the screws and does not fill the area anywhere near the way the oem one did.
