The main harness side of the plug in the picture is used. The fan side connector and the resistor are not (remove with the factory fan). The new harness plugs into the factory harness at one end. Those wires control the relays in the new harness. The new relays are wired directly to the battery. There is another plug (Chrysler) on the new harness that plugs into the Intrepid fans.
