Well installed the 86-7 ignition on my dad's car. Put an ac-delco module and coil in it.  It is better but still jumpy at idle.  The BLMs never got below 121 during the log.
It is still cutting off the injectors during engine deceleration, but way, way less than it was.
Can the IAT control fuel? Because I dont have an IAT installed in the car with the 86 - 87 comp.
During the log the ecm set the IAT to 76 degrees I believe, but it was 90 degrees outside.
So it may have been over fueling the car if it thinks it is colder than it is.
Before the ignition install the car would stumble badly about a second after engine deceleration (due to the 0% DC on injectors). Now after decel. the engine pops right back to idling.
The only real complaint is at steady part throttle it is still cutting cylinders out.
Tell me what you see.
Thanks,
Jerry
Thanks,
Jerry
