another new timeslip, 6.0L turbo
ITSNOTAGN
Shadow Master
put the drag radials back on, put some premium in it for the first time. Turned the boost up to 13psi, 10-11 degrees timing, non intercooled.
Stock converter is REALLY holding me back at this point, i was only able to build 2psi on the footbrake, 2200rpm. Honestly, its killing me. Guys in the other lane were putting 2-3 cars on me out of the hole.
ANyway
raceweight was 3770lbs, on the return road
3540ft DA
2psi launch, no tire spin
60' - 2.11
1/8- 7.88
MPH-99.6
1000-10.00
1/4 - 11.76
MPH- 126.3
My computer was showing about 625 crank hp. a quick run in a dragstrip sim shows that to be pretty close. But also it shows 500+hp from 4800rpm up. Another thing is its showing 500+ft lbs from 3000rpm in 1st gear (thats at about 3.5psi) until i let off, with an average of about 545ft lbs.
Comments?
Gary
BTW, i didnt realize until the launch that i forgot to take the street tires out of the trunk. the next run i scaled in at 3620lbs, Coulda had an 11.5! dam!
Cool!
Awesome buildup......
I have been thinking about planning something similar for awhile.... L92 heads... 6.0 truck shortblock... dish pistons...
I think you could make 1000 hp with pump gas and alky.... those bottom ends are waaaaaaaaay more beefy than our 109's.... they look like stage motors.... except with lots more cubes....
Again... cool project.
