Wow i am so glad this section is up. i (like alot of us) have been hiding out at turbomustangs for a long time. I just started this and got my motor about a month ago. been working on accesory placement and stuff before i got carried away. anyway i dont have any pics yet, think im going to re-do my motor mounts this weekend as they are about 1/4 inch too wide, might just try to tweak them a bit. also if you are using a truck engine, its really easy to get the accesories bolted up, ill post pics showing this later.
6.0L LQ4, 9.4:1 compression
Lunati 224/224 112 .560 lift. had it from previous build
Moly pushrods
headers by me, have everything just need get placement done first, 1 3/4 primaries and 3" collectors
Pro Products Typhoon intake
60# mototrons
HP Tuners 2-bar speed density
Borg Warner S400 turbo, 77mm
Powerstroke Intercooler
4 or 5" downpipe, whatever fits.
4L80E
looking at 500-600whp on pump gas with little drama. going to keep it at 10# or less until i opt for rod bolts and stuff. dont think i will have too much of a problem doing that. after running this combo through dyno-sim alot this cam is actually a pretty good turbo cam. also i had this in my GTO, and with the extra 17ci of the 6.0 i think it will fit just right. also with the better heads it should do 340whp N/a, did 363whp in my GTO.
Comments?? Suggestions?? post em
Gary
Moly pushrods
60# mototrons
4L80E
Gary
