Greeting all ,
After replacing the Check valve in my Power Master , I am still get cycle times of ~ 2 minutes.
Has anyone every tried installing a high pressure steel ball check valve in the high pressure hose Assembly like the Mcmaster Carr's 46105K65
McMaster-Carr
even if it was to only verify that was the only problem with the PM cycling?
They have brass body valves for ~ $15.00 , and the SS version is ~ $37, plus the fitting's need.
Is the pump outlet a 1/4" NPT ?
McMaster-Carr
