When you shut your car off after a drive, is it normal for the passenger side of the fluid reservoir(acc side) to fill back up with fluid or is it supposed to stay pressurized keeping the fluid in the accumulator ball. Also, with the key forward, the pump pumps fluid back into the acc ball. If i keep the key forward,after the pump stops,the pump turns on again after about 15-20 seconds. Is this normal? And lastly, i have a small brake fluid leak and i cant figure out where its coming from. It runs down the frame area by the lower control arm. What are some of the more common locations for these units to leak from. I have the updated switch.
