I have been trying to prime my motor. I am using the SBC priming tool. I do not have the turbo on the motor at this time and am getting good pressure through the turbo oil feed line. I ran clear plastic tube from the turbo feed line to the turbo drain line. I have pressure also to the top oil cooler line where it attaches to the radiator. I know this due to a slight leak it at the fitting that screws into the radiator. How can I verify that I am getting oil to any other areas of the motor? I removed the driver side valve cover but there is no oil coming up through the pushrods. I put 5 quarts of oil into the motor through the cam sensor hole. The dipstick is still showing that it is low about 1 1/2 quarts. Am I expecting too much from the priming tool to send oil up the pushrods to the rocker arms? I thought I would ask these questions before I proceed any further with the reassembly.
TIA Bill
TIA Bill
