Another Tire Size Question
Rayk
Let the Boost begin!
I’ve checked the tire size sticky and don’t find the answer:
Can I run 245/60 x 15 tires on the front of my Regal to match the 245/60 I have on the rear? I currently have 235/60 in front but want to be able to rotate the tires.
My wheels are the GN alloy replica wheels in 15 x 8.
First off, nice looking car.
If you’re at stock height, which it looks like you are, they should fit.
The 245/60-15’s are only 1/4” wider and 1/2” taller.
I know it’s hard to see sometimes, but there might be a way of measuring the clearance on the front to see if you have enough room.
I would put one of the rear tires/ wheels on the front, set the front down on a couple of sheets of cardboard (stacked) to make it easier to turn and check if they clear.
I had 255/50-16’s on all 4 corners back in the late ‘80’s. They were on 8.5” wide wheels with 4” backspace. The fronts rubbed just a little at the top of the fenders over large dips.
On an 8” wide wheel with the same backspacing there will be more clearance at the top of the fender.
