bigballsbilly
- Mar 29, 2014
SignUp Now!Ok Thanks, I will porbably let it be. I just wish it was paineed the right color.
Yep, I forgot the tape is there to cover the big holes for the locating pins, and roll pins only went through one side. Mine has been off, and the other column in one of my cars, someone unsuccessfully tried to cut it off. Leave that thing on your car and just paint it like pacecar said.the cap at top is only drilled on one side for the the roll pins to go in , you'd need to drill a hole on the opposite side to be able to push pins through , or get the paint from kirban and paint it .
the steadfast collar you had to pry the original chrome tabs off the old the ign lock , if you do remove it and keep it off you'll need to replace the lock cylinder
