what should i go with? 8" or 9" in the front. what back spacing? they would be 18" wheels.. also 18x10 in rear with 5.5 bs .frame notched wanna tuck some 315's... thanks joel
the advantage is that you can run a wider tire, but the disadvantage is that if you don't get the backspacing just right, you might have more rubbing issues.
I have 9.5" in the rear w/ 4.75" backspace. I have 315 tires. They are Nitto DRs and it's so close I doubt any other type of tire would work. Any more BS and you'll rub a stock frame. I also have rolled fenders.
