I think the vacuum must be stronger after the turbo, say at the adapter, since the same VOLUME of air is moving through, but the pipe is smaller, resulting in a higher velocity, and more VACUUM. Our bigger 3" intake pipes move the same VOLUME, but since it is larger, it is at a much slower rate, hence no problems with siphoning that you run into when connecting at the adapter.
Don't know if there's anything to this, but just my opinion. Let me know if anyone agrees.
I think if you went to the intake manifold on an IC car (which is essentially what you are doing at the adapter of a hotair car), you would see the same result. That's why noone needs a check valve on IC cars, since they go to the larger intake pipe (before the TB).
