The only problem with offset grinding or cutting them down to 2.100 is that the oil hole is at a angle. if you make the journal smaller, the oil hole will get to close to the radius. This will be a problem. I to looked at cutting one down and ran into this. My solution to this is to use a Pontiac 455 rod. It is the same housing bore as a 3.8 Buick rod. It is just wider so you can get the offset right. I am working on mine as we speek and will give anyone the dimentions if they want them when I am done. Only bad part to this is you have to use a custom piston. Ross is doing mine and they are not that bad as far as price. Anyway, It should work out just great...
